- Northern Vermont Lake Champlain
- Other
- Other
- Other
Last year shortly after purchasing our Yamaha, we noticed that the deep orange color was fading, as the sun had caused oxidation of the gelcoat. I wanted to wax over it, but that would be like putting lipstick on a pig, so I decided that if I was going to it right, first the graphics would need to be removed.
That just made the oxidation, where the graphics did not cover, more obvious. I purchased a kit from Marine 31 with a heavy cut oxidation remover, a final polish and a carnauba wax/sealer with several foam pads. Tried the oxidation remover with the D/A and it did very little. So not wanting to admit failure and call a Professional, I decided to wet sand the hull, It has been a while since iv'e wet sanded that big of a surface, but I bought some paper, 1500 and 2000 grit and started,
I wanted to go easy so I hand sanded, probably will use the D/A for the other side if I can locate the paper. It went well and a long way towards restoring the hull to its true color. I did use the Marine 31 products after the wet sanding and they worked well to restore the shine. Here are a few before and after pics.
We both like the end result.
