2006 AR210 Throttle Body Assembly Issue?
gtgt
I have a 2006 AR210. For the past month, the port engine will sometimes start up right away and other times it won't start unless I turn off all power to it, wait a few minutes and try again.
I have purchased an AR210 Service Manual and the YDS software. The software revealed the following Port motor error codes:
[Engine has 655 hrs.]
If I start the engine briefly and then turn it off, the port engine Throttle Body Assembly makes a whining noise until I cut off the power to it (turn off the batteries).
I'm not that mechanically inclined, but I can do simple repairs.
Has anyone seen these error codes before?
If so, are they consistent with replacing the Throttle Body Assembly?
Also, has anyone else ever had to replace the Throttle Body Assembly? Any tips?
If this is the issue, I'd like do the repair myself because the last time I took it to the dealer they had my boat for 3 weeks.
