2016 242SE Wake Tower/Bimini Bar Cracked!
Ky2fl22
Cape Coral, FL
We recently went through Hurricane Ian, and it was pretty brutal. My tower on my 242 cracked and I wanted to see if anyone else has dealt with this issue? I've attached pictures so you can see what I'm referring to. Can I weld this back together? Unfortunately, they do not offer just the top bimini piece, you have to buy the wake tower as well and it's around $15k. Thanks!
Sorry to see that maybe some type of sleeve could be installed with clamps and match it to the other side. Maybe try to contact the fabricator directly that made them for Yamaha I remember seeing some type of sticker that identified the maker . Other options watch copart for an auction see if they would give info about who they sell a boat to because you want to buy parts, not sure if they would give that info but they will surely be some swamped Yamahas from that storm. If you found one at copart you can go in to view it bring some printed papers with your info leave them in the glove box or other areas stating what you need, that’s a long shot. I did see some members that had the later model with adjustable Bimini single knob have the knob rattle loose from towing the Bimini flipped up one hit a bride the other ripped apart from the wind. They had a problem pre covid getting a tower or getting it in the correct color with an insurance claim.
For anyone that reads this its well known that the Bimini top left on should not exceed something like 50mph or so. Hurricane preparedness remove your Bimini top. Best of luck and keep us posted on the outcome.
it can be fixed...
I would think this could be fixed for 2k. Weld back together, smooth and paint.
What did you end up doing with your cracked Bimini frame? Identical spot as your pics on my ‘17 Limited SE. Haven’t contacted insurance yet
I took off the tower, loaded it on the back of my truck, and took it to a welder, who was able to weld everything back together perfectly. I'm in south FL, so there are people all over the place that do this. Hopefully you can find someone to help you out.
Thanks for replying and great to hear you didn’t have to replace the entire tower. Will try and do the same
Best of luck! It was under $500 if I remember correctly.
