2016 Yamaha 190 FSH Sport mods
William
Washington State
Bow fishing chair installed
Installed Garmin using rotary tool to cut the fiberglass ran wire to transducer below and power fuse block
Installed lights ran power to accessory switch
Installed them too high and they come out of the water, need to reinstall next summer lower and this time make them level lol
Installed head and toilet paper holder
Installed Thrust Vector to help with low speed steering
Bought cover for FSH sport, very nice cover, very impressed
Installed antenna on t-tops ran wire through tubing
Anyone have experience with installing autopilot on this type of steering?
veedubtek
Punta Gorda, FL
Scout
Is that the factory pedestal seat? I've been thinking of adding one on mine also.
No clue on the autopilot, seems that would be a daunting task, but I'm sure it could be done!
John McLaughlin
Ocean Pines Md
Great additions however the real question is have you caught sufficient fish to offset the cost of the upgrades?:)[flag]
William
Washington State
We just ordered it from the dealer, I don't know if it is a Yamaha part but Desert Valley Powersports parts department handled it for us.
Rich NW Jboater
Renton, WA
What part of Washington are you in? I'm in Renton and have the same boat
Rich NW Jboater
Renton, WA
surprised I've never seen ya. I just installed the Seadek cockpit kit and an Axiom 9 with RV-100 transom mount transducer last weekend. Come hell or high water, I'll be out on Lake WA Sunday afternoon, it's killing me
William
Washington State
Me too, I wish we lived in a tropical climate.
jaysen
can you show how you installed some of your modifications. im not sure how to wire the add on rocket launcher lights without using zip ties. also curious about the seat and how you were able to install it. what secures the head from falling over?
William
Washington State
For running wire through the t-top frame I drilled a hole at the entry point and at every transition. For example the structure of the frame between the green arrows below is solid so you cannot run wife through these sections, but you can exit and re-enter the frame after this section by drilling more holes. I just drilled the holes where most people will not see them and I used fish tape to pull the wire like you do at home when installing cable through walls.
A note on drilling, I recommend you plug your drain holes on your deck before you do any drilling and thoroughly vacuum the metal shavings after drilling, I let some shavings get in the drain tubes and it is not good at all.
The seat is easy. It comes with a big metal plate that fits perfectly under the deck that the stand sits in. You just drill the holes and tighten the bolts and you are done. Super easy I used the life seal you see in the picture below on every bolt and screw on the boat. You will see when you order the part.
The head comes with brackets you screw into the floor and then snap the head into the brackets. Again, very easy once you see the parts in the box.
William
Washington State
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
To the OP...forget autopilot. Unless you invent something yourself, AP doesn’t exist for jetboats.
AP requires hydrolic steering.
I have AP on my boat and it’s the best thing I’ve purchased to date.
William
Washington State
So you don't have a jet boat then? It looks like you have a 190 FSH in your pictures but you say AP does not exist but you have it. I am sorry I am missing something. :)
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
Used to have a 190...but after 9 months of ownership and 150 hours of fishing the Atlantic, I knew it was time to sell!
I now own a outboard center console.
William
Washington State
Nice, I love center console boats, they are my favorite, which one did you get?
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
Tidewater 250. It has its faults; however, it is an outboard and not a jet which was paramount for me.
