2kwik4u
- Buffalo, NY
Put about 10-12 hours on the boat this weekend.Yes do let us know I'm only turning like 7400 on the top end so curious to see how much you pickup with just removing the red one.
Had a chance to do a top speed run with just me and a 1/2 empty cooler in the boat. TONS of traffic, running from a rain storm, essentially as close to the "high seas" as you can get on a midwest inland lake. I came out of the water once and hit the limiter as the pump unloaded. It was nuts.....It also registered 45mph at one point. Not sure how much I believe that, but when it was in the water I was getting around 7550 rpm. Up about 100rpm from the previous top speed test I did.
Had a much heavier load on Monday. 4 adults, 4 boys (8, 7, 4, and 2). Plus 3 full coolers, 2 beach bags, a food bag, and a diaper bag. We were pretty well loaded down. Launch took a second or two to plane, didn't just "jump" out of the hole like it does with a lighter load. Still had zero cavitation on launch.
I did notice that when pulling a tube on Monday, that before when I would lean into a turn and get some loss of traction, that this phenomenon came on a little faster, and didn't recover quite as quickly as before. It's not quickly noticeable, but it was a small detail worth noting.
Overall, it wasn't much different than before. The changes were significantly subtle, and the wife noticed nothing different. Which tells me the changes are only obvious to someone paying VERY close attention.
Be curious to know if anyone else has a similar experience with changing shims.
