kkees
- Austin, TX
- Scarab
- Other
I have a 2012 Audi Q7 TDI S-Line 3.0 that does NOT have the fix yet. It tows 6600 and have pulled a 4100lb camper plus all my stuff for 2 months from TX to Colorado (approx 500lbs of stuff). Pulled it over several mountain passes including Wolf Creek and the one south of Breckenridge with no issues. I have a 2019 Scarab 195ID 300hp on order and know my Q7 will pull that boat very easily loaded down and full tank of gas. I'm terrified that this emissions fix due by September 1st is going to hurt towing at altitude, as it states that it effects the engine brake and performance at altitude. So far, the fix on the new generations 2013 and up, has had little effect. But it is destroying the Q5s, tons of issues. So definitely do NOT buy a Q5 with the emissions fix. Q7 sounds pretty safe with the fix, 2013 and up for sure. If any of you guys have a Q7 TDI and have had the fix, please comment on performance. I haven't found anything on forums with Gen 1 fix performance other than the AdBlue filter gets plugged sooner and Audi may be building a larger filter.
veedubtek
Did you say you have a Cayenne or looking at buying one? Just curious what your take is on the emissions fix?
veedubtek
