swatski
- North Caldwell, NJ
Hard to tell... I have had situations where it can take a few seconds for the speed to settle and stabilize, I kind of assume it is normal when surfing with a lot of ballast and the boat hull listed (rolled) to the side. Does the system act up at wakeboarding speeds?The OD is fine, checked the spec when switching to the Lucky 13 cone.
Seal and nicks might be a problem.
For Ridesteady, I've had some tries where I reached the desired speed, but Ridesteady would not really engage.
And other instances where the overshoot was too high (12 mph), but Ridesteady engaged/
In general I would think if you are cavitating heavily the system trying to adjust speed by varying RPM is not going to work out very well for holding speed precisely.
