Marvin willis
- Morehead city nc
I added speakers to the swim deck without cutting the cushions.
Same.Here is what i did in mine. I installed 2 tower speakers and upgraded the existing ones. No issues whatsoever. I love it.
I read somewhere or on youtube that the RCA and power should cross at a 90 deg angle. Don't quote me but that may be it.Anybody know how to fix the slight speaker fuzziness I have going on? Got the power and ground running down the starboard side along with the RCAs so I’m thinking it’s picking up the signal or something. Also I’m not sure if it’s a ground common or what’s the best way to fix it? Would conduit help protect it or no, and I’m really the only person who notices but it bothers me lol
weird. I wouldn't expect any issues from them. Only other guess would be a poor ground somewhere, but it's not like a car where you can "ground" anywhere.JL audio 4 channel
Couple of installer No-No's here that could be causing your buzz. First rule, never run the power wire for an amp with the RCA's. Most RCS's are prne to pick up noise this way. Number two, your remote wire! There is a remote wire on the radio and you will want to use that.Anybody know how to fix the slight speaker fuzziness I have going on? Got the power and ground running down the starboard side along with the RCAs so I’m thinking it’s picking up the signal or something. Also I’m not sure if it’s a ground common or what’s the best way to fix it? Would conduit help protect it or no, and I’m really the only person who notices but it bothers me lol
There is no remote turn on wire coming off of my fusion which is another reason I had a problem earlier in my install.Couple of installer No-No's here that could be causing your buzz. First rule, never run the power wire for an amp with the RCA's. Most RCS's are prne to pick up noise this way. Number two, your remote wire! There is a remote wire on the radio and you will want to use that.
A couple other thoughts...if you havent done so, dont put the sub in the panel by the captains chair. That panel is very prone to rattles. Oddly, the panel by the co-pilots chair doesnt rattle. If you want 2 subs, do one by the co-pilot and the other in the storage compartment behind the captains chair.
Good luck
Is your radio a Fusion MS-RA70?There is no remote turn on wire coming off of my fusion which is another reason I had a problem earlier in my install.
Yeah it isIs your radio a Fusion MS-RA70?
ok so it’s the same as mine. My guess is that you had to order a new harness cause the rca’s were cut by Yamaha. Still don’t understand why they do this but it’s just about every boat like ours. Anyway, the new harness, if it was like mine, has a blue wire that is the remote turn on. It’s also in the factory install manual.Yeah it is
Yeah what he said - the remote wire is what you need to delay the amp turn on. And ensure you're using the common battery ground to route all shielded signals to ground. No hum, hiss, or noise with my JL MX500/4 amp. Also check that the sensitivity is set correctly - if it's too high, it'll crank tunes very loud, but it also amplifies any background noise. There's a procedure to tune the amp properly and it makes a big difference to just guessing.ok so it’s the same as mine. My guess is that you had to order a new harness cause the rca’s were cut by Yamaha. Still don’t understand why they do this but it’s just about every boat like ours. Anyway, the new harness, if it was like mine, has a blue wire that is the remote turn on. It’s also in the factory install manual.
Would you mind sending me a link to your harness? My new harness didn’t include a remote turn on and I couldn’t seem to find one that did include itok so it’s the same as mine. My guess is that you had to order a new harness cause the rca’s were cut by Yamaha. Still don’t understand why they do this but it’s just about every boat like ours. Anyway, the new harness, if it was like mine, has a blue wire that is the remote turn on. It’s also in the factory install manual.
Are both these harnesses for the RA70 head unit? The first one states yes for RA70 but the second link doesnt state it is for ra70?FUSION Power/Speaker Wire Harness f/MS-RA70 Stereo S00-00522-10FUSION, Boat Accessories, Boat Equipment - Boaters Marine Supply
Power/Speaker Wire Harness for MS-RA70 Stereo Features: Power/Speaker Wire Harness Specifically for MS-RA70 Stereo WARNING: This product can expose you to chemicals which are known to the State of California to cause cancer, birth defects or other reproductive harm. For more information go to...www.boatersmarinesupply.com
FUSION Wire Harness f/ MS-RA670 & MS-RA770 Stereo - Zone 1 & 2 (B Port-RCA) 010-12812-01FUSION, Boat Accessories, Boat Equipment - Boaters Marine Supply
Wire Harness - Zone 1 & 2 (B Port-RCA) Compatible with MS-RA670 and MS-RA770 stereos FUSION's Zone 1 & 2 Harness Wire for installation. WARNING: This product can expose you to chemicals which are known to the State of California to cause cancer, birth defects or other reproductive harm. For more...www.boatersmarinesupply.com
