Michal
- Hampstead, NC
- SX195
It's your boat do as you like maybe change the air in the trailer tires as well just to be safe.Thanks Jeff, I know what they do and its purpose. Others say to change it as part of regular maintenance every couple of years and that makes sense.
WTF? Your posts are always like this on all the threads. You act like you want to help and then say some shit that don't make sense. Not sure if you're joking or trying to be an asshole? Thanks for totally derailing the thread.It's your boat do as you like maybe change the air in the trailer tires as well just to be safe.
That describes your post very well I was just kidding maybe when you get a lot older you will understand and I am not kidding here . Now stop crying I promise I won't even mention the blinker fluid .WTF? Your posts are always like this on all the threads. You act like you want to help and then say some shit that don't make sense. Not sure if you're joking or trying to be an asshole? Thanks for totally derailing the thread.
Got it out and replaced. Did as you suggested. Backed the manifold bolts out a bit. This opened up just enough space to get the old one out and the new one in. I was about 1/3 to a 1/2 used up on the anode. That's 5 years of mixed water usage and flushed after each outing with saltaway.Looks like leon has the non supercharged engine. It's a different intake manifold. The manifolds have o-ring gaskets so just unbolt it and move it forward a little.
