bleudyno
Sometimes the MFR will forget to remove the mold release compound before applying the non skid pad. In this case it appears they forgot that step. I'd make sure that you aggressively and liberally apply acetone to the areas where your new SeaDek pads will be installed. This will ensure that they don't lift.
The pad was securely attached - it would not have lifted off with normal use. It took quite a bit of force to lift it off but I think the main thing here is that the adhesive that was used peeled off cleanly.
