Okay, so some (not so good) update.
I ran out of work today, picked the boat up at the SCBM and ran to the closes ramp, Hideaway Harbor on the Mississippi.
It was a bit chilly, I was not exactly dressed for boating as I ran out without a coat, a beautiful day otherwise...
I was cold as heck after few minutes of riding, still enjoyed the beautiful bluffs and Grafton, IL - in the background.
I started with clean oil, after the SCBM replaced and flushed the engine, they used some 40 qts to get that done.
Both engines started with no hesitation and worked just fine to my ear, no funny noises, seem as normal, no rpm drop (I had the RideStready off and the sync off so that I would be able to see any RPM drop, there was none.
Per Jerry's advice, I ran the boat for about 10 min at midrange, keeping the rpm somewhere 5,500-5,800. He advised I then check the oil and if everything looks good, proceed to WOT for few minutes and check again.
Unfortunately, the milkshake returned after the first 10 min at midrange, so I limped back with the port (affected) engine at idle, running high on the strbd engine.
Basically, that indicates water intrusion due to something cracked, not just blocked exhaust or water backing up.
Not much progress I guess but enough for the SCBM to now call Yamaha and get them involved, see what they say.
I'm super bummed, having the boat in this kind of predicament is driving me crazy. But, I'm also very encouraged and grateful for the dealer's posture! both Jerry (the owner) and Pat (the master Yamaha mechanic) seem committed to figure this out, I don't think they a going to leave me hanging out to dry. I just need to be patient, which is hard, lol.
