I just installed thrust vectors and rear lateral thrusters on my 2024 222XD. I noticed that each jet is slightly pointed to the middle….is that the proper alignment of the jets? View attachment 225779
don't you want them toe out slightly rather than inward? I have the cobra jets have them towed outwards (opposite of what's pictured).That looks like a great result to me. Toeing them slightly inward will give you a slightly more concentrated area of thrust and wake, which is great for watersports.
He has a wake series, the fins are NOT straight. They are roughly 3/8 difference on the cable lengths. Port will be shorter, starboard longer, to create the canted alignment.@Bloomgren I think that fins aside... it's more about the jet nozzles and how they should be aligned. I just checked the Yamaha Service Manual, which states they should be “straight back”. See pic. So if nothing else, I would just realign them so they are straight back and parallel to each other. And then you can call Jet Boat Pilot on the phone (they will actually answer) and see if they recommend for the Thrust Vectors to add any additional slight “toe-in” like I did on mine.
Smart idea. Thanks for this tip.Another thing you might like while you're doing this @Bloomgren that I did, is while you're doing it and have everything including of course the keel, centered perfectly.... Go back in the boat and put a black zip tie on the middle top of the steering wheel. I really like it because when I'm driving or docking I can easily see and feel when I have the steering wheel / keel straight.
A suicide knob/wheel spinner works well too. Once you have everything centered put the knob on top of the wheel so you know where center is. I like steering with the knob a little better too.Smart idea. Thanks for this tip.
literally says " i have a 2024 222 XD lol.Fyi - has a 222SD, not XD, so it's not the Wake Series, but what you're saying might still be true for his idk. That's super interesting, so yours came what I'd call "toed-out", with the front bow side of the nozzles further away, and the back stern side of the nozzles closer pointing towards each other. I would have thought that would make driving the boat straight and steering a little more squirrley. @Wicked92 did you notice the boat tracking better when they were parallel versus toed-out? If not, I might give that a try to see if it cleans up my wake spray.
Oh whoops, I looked at his boat model in his profile where it says SD and not his post. lol.literally says " i have a 2024 222 XD lol.
"I just installed thrust vectors and rear lateral thrusters on my 2024 222XD"
All wake series boats have surfpointe. Which is canted jets. I didnt notice much difference on mine in regards to steering. Its not a huge amount. My boat without to have nozzles straight is 11.8" roughly to the center of eyelet of the cable mount measuring from pump baseplate.. Surfpointe is 11.4 port, 12.2 starboard respectively.
For a different look... my son and I used gold fingernail polish and painted the Yamaha logo on the steering wheel. There are three legs to the logo, and one leg of ours is gold, the leg pointing straight up when the nozzle is straight.A suicide knob/wheel spinner works well too. Once you have everything centered put the knob on top of the wheel so you know where center is. I like steering with the knob a little better too.
