Matts18
- East Tennessee
All,  I have had an issue with my boat (AR 195) the last two trips out that seems like it could be heat soak.  The first time it happened I had been running at full throttle for a few miles and the rpms and speed slowly (about a 15 second time frame) dropped a bit (low 40s).  There was a bit of debris on the lake that day so i thought maybe I had run over something so I stopped and checked the clean out and it was fine.  Acceleration the rest of the day and speed was not up to par but other than feeling "soft" the boat ran ok.
Went on a long ride this weekend and the boat seemed fine. Did a few full throttle bursts and speed and acceleration felt normal. We stopped for a few minutes to jump in on the way back and acceleration felt pretty sluggish for the rest of the day and top speed was in the low 40s.
Does this sound like heat soak? Nothing in the clean out port and a visual inspection on the trailer showed nothing in the pump. I pulled the white strainer out and it was clean. Boat has about 28 hours on it, on second oil change and original spark plugs. Water temp was in the high 70s both days and air was in the low 80s. Two people on boat.
Thoughts?
Thoughts?
