haknslash
- Lake Martin, AL
- Moomba
- Other
Damn that is crazy!Yea I removed that comment. The RIVA instructions show an additional rubber faster that goes in between the throttle body plate and the ribbon but this was for older engines. Newer engines just have the rubber gasket around the ribbon.
Can't believe our engines can even make power with this damn thing in there!
Glad you got it man! I missed your message this afternoon. It takes a bit of wrestling! When will you have it out on the water again?
Yes it will feel a bit stronger out of the hole and while stabbing it at RPM. The throttle response is better. I didn't pick up much mph but I'm wondering if the naturally aspirated guys get more from this mod than us supercharged guys? I was hoping to hit 50 at least but it is what it is. I forgot to mention this was with 87 octane fuel. I may try a higher grade and see if it makes any difference (doubt it). I know the 195/SVHO guys have to run premium fuel but I'm sure that has more to do with the higher boost of the larger supercharge wheel.
