haknslash
- Lake Martin, AL
- Moomba
- Other
Damn that is crazy!Yea I removed that comment. The RIVA instructions show an additional rubber faster that goes in between the throttle body plate and the ribbon but this was for older engines. Newer engines just have the rubber gasket around the ribbon.
Can't believe our engines can even make power with this damn thing in there!
Yea I am glad you did this write up. Taking all the stuff off sucks but once you get it off the intake manifold can just flip like you mentioned. Worst part for me was the stupid nuts on the throttle body. Getting my arms and body in the engine bay and trying to wrestle those things pissed me off haha. Not to mention I dropped a washer under the engine while taking it off!! Then when I was reinstalling the same nut and washer sure enough I dropped it again because my fingers were wet from loctite!! I fished the washer out but couldn't find the stupid nut. I must have looked for 10 or 15 minutes crawling all in the engine and scrapping my fingers all up trying to feel for the nut under the engine, shaft housing....everywhere! Just when I gave up I moved my tools in my lap and the stupid nut came out of the drive socket lol. Stupid thing was in there hiding the whole time.Glad you got it man! I missed your message this afternoon. It takes a bit of wrestling! When will you have it out on the water again?
woow I'm glad I got the 16 vs 17 I had no idea the SVHO runs premium fuel.Yes it will feel a bit stronger out of the hole and while stabbing it at RPM. The throttle response is better. I didn't pick up much mph but I'm wondering if the naturally aspirated guys get more from this mod than us supercharged guys? I was hoping to hit 50 at least but it is what it is. I forgot to mention this was with 87 octane fuel. I may try a higher grade and see if it makes any difference (doubt it). I know the 195/SVHO guys have to run premium fuel but I'm sure that has more to do with the higher boost of the larger supercharge wheel.
