Audio Zones Wake and Non-Wake Series Boats
kgower
Buford, GA
222SE
Our 21 195S (for sale) and our 24 222SE have two audio zones.
Do wake series boats have 3 audio zones, tower, cabin and sub?
I was reading an FB Yamaha group post yesterday indicating 3 even 4 zones (4th being transom speakers).
Is this the best way to achieve at least 3 zones; Wet Sounds™ Marine Multi Zone 4-Band Parametric Equalizer? Will the zones show up on the screen?
Any expertise appreciated. photos, wiring diagrams, equipment suggestions would be a huge help.
I use two of these to control zones on my boat. Each one splits 2 rcas into 4.
They work well, no noise or anything.
I did the install on our 195S, but had a shop do the install on the 222SE. I will need to look again, but I don't believe there are any RCA jacks just harnesses.
I went 6 zones it was easy to use two Eqs on the 2017 model one RCA to each EQ that feed 4 amps with six pre amp RCA signals then the amps run to 20 speakers / subs . Boats need a lot of fine tuning and require different set ups based on how its being used and the type of music being played. This set up is very easy to adjust while on the fly with out being distracted trying to look at screen and go layers deep into menus to adjust.
