tdonoughue
- The Woodlands, TX 77381
Found this from BoatUS:
(after a section recommending dry chemical extinguishers over CO2 and other gaseous extinguishers for cabin fires...)
The same dry chemicals that are so effective in a boat’s cabin aren’t much use when a fire breaks out in the engine compartment. The reason has to do with how the two types of fires are fought.
Accounts of engine fires typically began with a warning?a burning smell, a loss of engine power, or even smoke trailing after the boat. If someone then opened the engine hatch to check out the trouble, he or she was usually overwhelmed immediately by flames and smoke. Fires need two things: fuel and oxygen. Opening an engine compartment hatch to look for a fire is like throwing gasoline on hot coals; it fans the fire with a rush of fresh oxygen.
The solution is to leave the hatch closed and fight the fire either with a fixed extinguisher in the engine compartment or with a portable extinguisher discharged through a fire port (a small opening into the engine compartment), which is why dry chemical extinguishers of any class are inappropriate. Blindly spraying a chemical extinguisher through a fire port does little or nothing to stop an engine fire because the chemical isn’t being directed toward the base of the flames. A gaseous extinguisher, on the other hand, extinguishes the fire by affecting the oxygen supply. The same extinguisher that wasn’t effective in the wide-open spaces of a boat’s cabin will be much more effective in a cramped engine compartment.
For this reason, among others, the ABYC recommends that either a portable gaseous extinguisher be provided near (outside) the engine compartment or a fixed gaseous extinguisher be used inside the engine compartment. In the event of a fire, either option eliminates the need to open the hatch.
Edited to provide full link: https://www.boatus.com/seaworthy/swybf.asp
