FloJet
- Moore, Oklahoma
Haven't really look closely to where the remote is coming out of but I don't necessary always mean the connext. I say that just because it's the main hub. So really the remote blue wire not the one with blue/white coming out of the head unit.
First, amps have a remote built in them but they need a signal for that to work. Second if you have multiple amps and equipment, it's not a good idea for a head unit to turn all those on either remotely or by daisy chaining them. This can cause power burnout issues. So best way with multiple equipments would be for the Head Unit to turn on the remote relay, then the relay pushes power to tell the amps to turn on. HU remote wires no don't produce enough regulated power to turn on multiple equipment or not designed for that aleast. Sure it can do it but over time you run the risk of damaging your equipment.
My setup goes like this,
When I turn the connext system on, there is a delay for amps. Once Head unit sends remote signal to the relay, the relay turns on all my amps, fans, leds, and other equipment. This also helps when turning the system off. It guarantees no stray power to equipment while the connext is off. This helps to not hear that bad feedback/loop noise from subs when you the power everything off.
Hope this helps.
Hope this helps.
