Betik
- Frisco, TX
- SX
It's more mental than physical. You forget about the physical part once you start the crossing. Everyone new to the Bimini trips for 2018 should get a chance to read the experiences people on 2017 crossing went through to get an idea of what to expect.It's all up to the captains abilities and how much abuse they are willing to endure. There's tons of information on this site about rough crossings and folks not prepared mentally and physically. It's an amazing trip but you have to be prepared.
I don't think you need 100 gallons of spare fuel but for Exuma I would probably bring enough fuel to make it to Nassau. Abaco supplies and fuel were readily available on our Exuma trip we go stuck in Chub waiting
I have a feeling I will be the only one on my minivan making the crossing for Exumas. SO I am not worried about getting an extra fuel tank.
I wouldn't bring a fuel bladder but you will need to bring extra fuel as a precaution. I had a boat similar in size to what your looking at with the 8.1l mercruiser and can tell from experience you can expect about 1 mile per gallon in moderate conditions as it can be a pain...
Wow, that surprises me. I have twin 5.7i blocks (300HP each) and even in moderate seas I get better than 1.5mpg running 25mph.
I've never ran her in more than sustained 3' chop though.
@James R Whitten I think there are 2 more scarab's going on 2018.
It is @Rick215HO and another guys whose name I forget right now.
PS. you might want to make up your mind in the next month or so and then start prepping.
Physically I mean prepping your boat. Fixed amount VHF radio, Chart plotter/GPS, additional bilge pump‘s, additional fuel if you think you might need it. And pack light. Ounces make pounds which equal more fuel burn and you need a higher speed to stay on plane.It's more mental than physical. You forget about the physical part once you start the crossing. Everyone new to the Bimini trips for 2018 should get a chance to read the experiences people on 2017 crossing went through to get an idea of what to expect.
Do we need to add additional bilge pumps to the minivans ? I need to upgrade the vhf and gps anyway.Yes but there is a huge difference in additional 4ft of boat and twin engines pushing 600 hp versus a single pushing 375 (what mine pushed). Even with the 8.1l that single will feel under powered at times I know mine did. In flat calm water it was fine in 3 ft chop it was under powered. Two props spinning from two engines would have made a world of difference compared to the single in the torque range to get back up on plane. On plane running 25 mph I was probably getting in the 1.5 to 1.8 mpg range.
Excellent. The way I prepared for Bimini 2017 is by going to Tangier Island in the Chesapeake Bay from Piney Point MD ( which is a good 33 miles ). You might want to do a couple of practice runs in Chesapeake Bay by choosing distances close to 50 miles. The conditions you get in the Chesapeake Bay is one third what you will experience during the crossing to Bimini.Excited to follow this thread along, planning for 2019. Will be doing hardware prep on the boat this year, as well as doing some ocean running to get a feel for it this summer.
I have two 2,000gph bilge pumps in the back, one on a float, the other on a switch. I also have a 500gph in the fwd bilge. Then the shower has its own bilge pump of unknown gph.
*** IMPORTANT ***
If you increase bilge pump size, make sure the fuse or breaker is rated for the larger pump.
The previous owner of my boat boated in the Gulf and upgraded the 1,000 gph pumps to 2,000gph pumps and was all proud about it. Once i realized neither pump worked, i found out he never upgraded the breakers, and running a 9A pump on a 5A breaker allows it to run for just about 3 seconds.
If he had ever popped a hose, she would have sunk with no working bilge pumps.
Thanks @Berrie . I will definitely look into this.If you boat alone - especially off-shore - i would invest in a Fell (wireless marine lanyard) or similar device.
It gives you the freedom to move around and kills your engines if you fall off.
I wouldn't go off-shore alone without it (don't have it now but will in the future).
I would prefer not being lost Life is too beautiful to be "lost"@Berrie , I am have the feeling that @Amar Nanduri 's life insurance has "being lost at seas" clause that makes his family millionaires overnight. But he cannot really talk about
