Boat creeping at 1 mph while in neutral
Brian_NY
252SD
I am having a problem with my SX 240 creeping at 1 mph while it is in neutral. I tried to adjust the buckets so that they are within specs. The port jet bucket is exactly 1 inch open while in neutral and the starboard nozzle is 1 1/8 inch open. The creep is worse now that I have the Ultimate fins with mega fangs. The problem is that I have no more adjustment threads left on the arm that controls the buckets, I am getting dangerously close to the ends.
Does anyone have any suggestions on how to address this. The creep is very prominent.
Thanks for any help!
Brian
rkluck
Powder Springs, GA
The boats will move a little depending on how you adjust the buckets but it should not be a more forceful motion in neutral. The goal is to have the buckets fully out of the way when going forward and to have a balance between forward and reverse for neutral. I think this adjustment may be in your manual. You can also try it and check the results. As new as your boat is I can't imagine something is worn out already causing a problem. I can get a copy of the adjustment process if you need it. There are also several you tube videos on this.
Osric
I'm unlikely to be of any help but maybe photos would be useful to those who know how to adjust these.
Gym
Falmouth, MA (Cape Cod)
I agree @Brian_NY. 1mph is excessive. That assumes you are in low idle mode, not no wake mode. You should find more adjustment at the cable ends in the throttle quadrant. There is info in the FAQ section as to how to access these cables. @Speedling did a nice write up on the older throttles that should be pretty much the same as the older ones.
Brian_NY
252SD
I was not aware that I could adjust the rods at the throttle quadrant. The boat was in calm water at the launch in "neutral", no wind or tide and the boat was creeping according to the speedometer at 1 mph. Very noticeable for sure. I had to keep bumping into reverse to keep from going ahead. I will look in the FAQ for more info when I get home from work. Thanks
Gym
Yes @Brian_NY The cables are threaded and adjustable at both ends.
Speedling
Cedar Lake, IN
SS
Do understand that the engines running means impellers are spinning ad pushing water. The gate is simply a balance of forward and reverse to find a happy medium.
I like moving forward slowly in neutral actually. It allows me to creep up to a dock or raft up with very little speed. I find it perfect with the thrust directional enhancers from JBP as well so i can side step right to the dock for fuel or whatever.
Hope it gets to where you want it but there is no neutral!
Cobra Jet Steering LLC
See where the reverse buckets are sitting when in neutral the buckets are supposed to balance out the amount of forward and reverse thrust to create neutral it usually is not all that accurate and the boats will move forward a bit, the cables at the bucket attachment may be the only thing you need to adjust if you lengthen the cable adjustment to it drops the bucket a bit lower , you will create less forward and more reverse thrust Also the buckets must be even with each other or you end up with the boat wanting to rotate one way or the other.
Speedling
Cedar Lake, IN
SS
Hey Jeff, with the cobras you think his effect would be more distinct the way they channel the water?
well the mega fangs create more useable reverse thrust so they could cancel out some of the forward creeping but I think he just needs the reverse buckets lowered a small amount or his idle setting is too high
Brian_NY
252SD
Does anybody know what the idle rpm should be. I though it was too high at 1300 rpm x 2
Brian_NY
252SD
@rkluck if you can get me adjustment procedures I would appreciate it.
Thanks
Gym
That is higher than my older boat.
Brian_NY
252SD
Can someone tell me where and how to adjust the bucket link from the opposite end of the bucket please. Thanks
rkluck
Powder Springs, GA
This is from a 2010 but it will give you a good idea as to what it should look like.
Brian_NY
252SD
Thanks for this, I really appreciate it.
