- Naples Florida
- SX
Are you running both at the same time on the same hose?
Heavens no, one at a time. I may be mechanically inept, but I spend all my spare time on the forum and so I am at least well read!Are you running both at the same time on the same hose?
Back to your fuel issue..... We now know that you have approximately 20 gallons of bad fuel. Hopefully, with the additives you've added, you will be able to burn off everything and won't see any more issues. I think that the fuel senders will show full or fuller than normal if water or ethanol is present.
The water flow difference might be that the thermostat hasn't opened yet and thus more more is passed through the exhaust.
Not sure but if you are not overheating I wouldn't worry.So not necessarily abnormal?
Thanks @Murf'n'surf I'll let you get to bed now!Not sure but if you are not overheating I wouldn't worry.
You could look for pinched hoses in behind the motor.
I am sorry I missed out on this conversation! It was a doozie! Glad you got them running @Stefan Fromm , these guys used to amaze me, but not anymore...we have the most willing to help of anywhere I have ever seen.
I can help on one topic being discussed. The water flow from the pee holes when running an engine on the hose is irregular and unpredictable boat to boat. And the hose from the port side engine is considerably longer, making it harder for it to even show any flow at all. My '08 rarely showed any flow on the hose. Even when I would nudge the throttle to around 5K rpm to warm my oil for an oil change, I didn't get any flow from my pee holes. So I wouldn't worry about that at all. But I would damn sure want to see good flow from all of them when running at cruise on the water!
Glad you found the issue on the rough running. Now to the plug change. My fingers are crossed and I have said a prayer to the Boat Gods that the plugs come out in one piece. I guess we don't need to say how important annual spark plug changes are and the need to use anti-seize on the threads. Apparently the previous owner didn't. Also, don't use a torque wrench on them. Hand tighten with the extension but no ratchet, and then turn 1/4 to 1/2 turn more with the ratchet...and your done. They will come out easy next year. Fingers crossed!
That's right @txav8r .... The stuck spark plug.
Try removing that stuck spark when the motor is cold. Don't over torque it! I did and had to get the head removed and repaired.
Run your fuel out and get that problem solved before moving on to the sparks!
