@atldude it sounds like your really diving into getting that boat ready for the spring great write. The neutral issue you mentioned is not really an issue its just one of the caveats of having a Yamaha jet boat the only true neutral on the boat is when the engines are turned off. When ever they are on the impellers are pushing forward whether in gear or not.
Boy, you are really going through this boat good. We have the same boat by the way! Can you tell me where you got the channel seal for your port hatch? I'm assuming you're talking about the gullwing hatch. Mine are coming apart and I want to replace them. I've priced them from the Yamaha part stores and they are crazy expensive for what it is. Somewhere in the $25 range for a hatch gasket. Really!?? If yours were about that then I'll find some apoxy for rubber and try to repair them.
I'm enjoying following your thread by the way. Impressive!
Are you referring to the port storage compartment door that also doubles as the walkway windbreaker? I'll have to get it for you Monday afternoon since we are enjoying the big boat this weekend. I store the Yamaha at home so I can get right to it when I get home from work.I have a request for you if you're willing to help me out since you have the same boat. Was going to order the oem folding door assembly but it's on back order so I'm back to doing it myself. Can you measure and tell me the size of the hinges? Like width and length and the distance between the center of the holes horizontal and vertical? Would greatly appreciate it if you could!
Hah yea not a pretty sight. There's no telling how long they have been there. Keep in mind boat was over filled with ~2qts per engine when I got itMy plugs have never looked that dark. How long were those in the boat?
Yea I know what you meanGives me the willies seeing those butterfly valves wide open. I am afraid I will drop something in there so I plug them with rags right away.
No problem at all! I'll get to it this afternoon. She's in a garage that's not attached to the house so I need to check on her anyway.Hi Pearce!
So I've been looking around and was hoping if not too much trouble could you tell me how thick the hinge is as well? Sorry just occurred to me a bit late![]()
