BigAbe75
- Litchfield, IL
- X
The swivel is what swings the boards in. It isn’t a complete 180 spin though. Mine spins about 135 degrees ish??
So, if rack is facing straight out away from boat, 90 degrees would point the rack straight to the rear, plus another 30-45 degrees toward the inside of the boat. If that makes sense?
The quick release part is a bolt with a rubberized knob that attaches the fork to the swivel base. You can get the quick release without the swivel. But, in practice, you wouldn’t use it that way unless you were standing on the dock.
So far, I don’t really see why I need the quick release. I’ll rotate the rack then take the boards off and just leave the rack where it is. But it’s cheap enough to add, might as well get it while you’re at it.
