Replying to my own post. I did find a couple of older posts that helped, then I called ShuttleSlide to confirm. I was quite confused about the whole thing, but I now understand that for the 255 FSH we need both the quick release from the TM vendor (Minn Kota RT-54 in my case) and the ShuttleSlide sliding quick release mount to work. She also clarified that we need the longer 6” mounting bracket to get the reach that we need on the 255, so I am super glad that I called.I’m a bit confused on the mounting bracket. Do I need a quick release from Minn Kota and the Shuttleslide quick release and bracket?
Great.1) Yes.
2) Never get any complaints. Easy to take off for sand bar trips.
Thanks![]()
Great.
Would you buy the Motorguide again, now that you've had it for awhile? I guess they're getting cleared out and are a good price so I'm thinking about one of the exact same models.
Has your battery size been sufficient for your needs? I keep finding 50Ah and 100Ah, but the forward space in the console tapers as it moves toward the bow, making it not ideal for a battery of that size (based on my measuring this afternoon). Might have to put some kind of a riser down first, not sure.
Imma take the liberty of jumping in here on the battery size.. that is highly dependent on how much you use the trolling motor. I use mine a lot and have three 100Ah battler born LFP batteries, before that I had three flooded lead acid batteries. Zack installed a DL 63Ah / 2.2KWh 36 Volt trolling motor battery, that looks like a great choice as far as run time, weight and simplicity. If you use your trolling motor a lot like I do, then go with the 100Ah LFP batteries. Zack says basically the same in post #18. Also, if you are not willing to pay the money for a Dakota Lithium, Battle Born or ReLion battery stick with flooded lead acid batteries. LFP batteries are some serious coin, but, if you decide to sell this boat you can always just pull them out for the next boat and put in a set of flooded lead acid deep cycles for the sale.
Again, depending on how much you use your trolling motor, it may or may not be important to you about whether or not said trolling motor will interface with the Simrad unit. I’m pretty sure @Roger Vrooman put a motor guide troller in his boat ( he sold his 255 and I have not seen him around in a while) and he had a few issues with it staying synched to his Simrad, I don’t know if @Zackdadams has tried integrating his trolling motor into his Simrad unit, so he will have to comment when he can.
I’m going to send you a private / direct message as I do not want to hijack Zacks thread any further.Thanks! BTW I have a couple of your upgrades bookmarked and want to roll some of them out to my 220 Sport. It's an impressive list of things you've done to your boat, sir!
I have essentially assumed I'd probably go with the 100Ah LFP. Were you saying that, in your view, there are only a few manufactures that are worth buying? I'd found some other fishing guy talking about a brand called LiTime, which seem pretty good I guess. Dakota is very expensive.
I'm a noob on all things marine. We bought the boat in early October and have had it out about 6-7 times and we love it. I quickly realized that I'd never be able to fish here in Charleston without a trolling motor, so I'm working on that piece now (obviously). I don't have a huge budget for this, and the Xi5 trolling motors (72", 36v) are now a good deal, at around $1,700; but I really want to fish and take my kids fishing, so I don't want to get a tiny battery either that unnecessarily limits our abilities.
I have a Lowrance Elite FS9, and I know that with requisite adapters the Xi5 will work with it, but I think it has to run an older software version, etc, so I'm fine just using the remote control, at least for now. I've never had a boat and never had a trolling motor, so I want to make sensible choices and go/learn from there; don't necessarily need all top-shelf stuff right away.
Thanks Zack!I don't use my trolling motor a lot, but when I do, my current battery seems to run all day; never had it die.
I don't have it tied into my simrad at the moment, although I have bought all of the cabling to do this.
That's the reason I went with Motorguide.
An optional upgrade.
Just another future project.
Also @FSH 210 input is always welcome!
I actually spoke with them the other day and the woman wasn't exactly sure what I needed. I told her it was probably the same as the 252/255, which she was familiar with. She said that requires a slightly longer BMAP-RE, as you said above (I think).Shuttle Slide will call you when you order, to double check which boat you have.
They will send you the parts recommended, which are the ones we listed.
You want the motor to retract in past the hull, so the mooring cover fits properly.
You had to get the BMAP-RE because the SS-7 essentially wasn't long enough to overhand the gunnel and allow the shaft to clear it, right? I guess I'm trying to figure out why you went with the SS-7 + BMAP-RE instead of the longer SS-9 and have it overhang the gunnel the way the factory one does? Personal preference?
On another forum I saw some people used a thick piece of aluminum plate made which they bolted to the gunnel and then mounted the trolling motor to that. Personally, I think I'm less bothered about something that overhangs than I am something tall on the gunnel, for whatever reason, and I'm trying to figure out what another good, solid mounting option might be.
The ShuttleSlide mount does look ugly as sin. Considering your preference for something that extends forward vs. something that stands tall & ugly, I would recommend you go to a marine outfitter or welder nearby and have them machine you a stainless steel plate that exactly matches the size and hole-pattern of your OEM mount. Then sandwich that plate between the OEM mount and the base of the trolling motor (or quick-release mount). Going this route will satisfy your preference for a lower-profile mounting scheme — and you'll save money.
I have a Motorguide Xi5 integrated with my Simrad MFDs. Being able to touch any point on my MFD's chart, downscan, or sidescan display and command the trolling motor to move the boat to the exact location that corresponds to that point is a crucial feature. In other words, if I pass over structure that's holding fish, I can just click on the sonar image of the structure/fish, and command the motor to take me back to that spot. The integration also allows me to use the Xi5 as a bow-thruster when I'm trolling on autopilot, using the main engines for forward movement.
If you go with a Motorguide, there's a simple mod that you have to do to prevent the Motorguide from literally falling apart. I'll have to dig up the description and photos I sent to Roger Vrooman back when he did his Motorguide installation. Every Motorguide I've seen fail, has failed in the same, easily preventable way.
I did get an Xi5, so I'd love to hear what the fix is to prevent the common failure, if you're able to find it.
Im curious, what is the motor guide design flaw that you mitigated with your modification?
