Theryan
 - Minneapolis, MN
 - SX
I agree, a switch cuts off the battery connection for safety. I don't need to charge on weekends as I'm using the boat, but plug in the on-board charger if I'm not using the boat for a couple days or more - like during the week - to keep everything topped up and ready for the next outing. A switch ensures there is no battery drain in the event you forget to charge or don't need to charge every day like me.
My charging system will top back up to full on both the start and house batteries if I run at cruising speed for 15-20mins after hours of floating (figure about 30 amps total available to charge), but I'm only running a digital amp (JL Audio MX500/4) added on to the stock Fusion and Connext 6-speaker system - it doesn't draw that much unless we're really pounding the tunes, and most of the time we're on or near the boat so we don't have it cranked. Some times we're very close to the ramp and it won't get topped up, and on those days I'll plug in the charger to make sure they're good, but most days we're a bit further and the batteries hit 14.2v or more by the time we're back at the ramp. Once the engines are off, surface voltage is 12.7v which is perfect for turning off the switches as the batteries are at 100%.
A critical part is ensuring you have a good multi-stage smart charger as well. A good one is marine certified and ignition protected so you have no worries of sparking the hydrogen gas if the batteries vent (sealed batteries typically don't vent with these chargers). And the multi-stage will top them up and maintain them at 100% by cycling on and off to keep them topped up without worrying about over-charging.
Yeah, I've got a nice Noco smart dual bank charger.
Realistically, not feeling like doing the switch also comes from feeling like I don't want to spend the time doing it if I don't need it.
The ACR should allow the stator to maintain the charges (I don't believe that our boats actually charger like an alternator, but rather just maintain where it's at, but keep me honest if I'm wrong).
I always plug in and leave my plugged in when at home, so it's never a big issue.
I also honestly have fears of hooking up the switch incorrectly and don't want to have to get a bunch of new wire, etc. to do it if it isn't necessary.
