Carb Pop Off Pressure
the MfM
I’ve been using Klotz skicraft...had looked at Klotz super techniplate which is already 20% benol. But Klotz says both Benol and the super techniplate are for pre mix only.
Same with 927... maxima says pre mix only
the MfM
Ready to go back in the boat
4x15mph
Downingtown, PA
Those look clean. What did you use to clean them up?
the MfM
Chrismer32
@the MfM - I just went through my emails back when I sent my carbs out. I asked for the settings and I was told they used:
1.2mm seat with 95 gram spring
Pop off wasn't tested since I was told they were all new OEM parts. I didn't push them on this since they are the experts
"They did recommend adding some castor base lube to the oil package...injection or premix
Castor oil protects the engine and carb internals like nothing else. it is expensive,, but you only need to use 1/4 of it in place of your regular oil. Maxima 927 or Klotz Benol"
How did the boat run with those settings? The gold spring with the 1.2 set. I'm about to rebuild my carbs and I want to set then up as close to stock as possible.
