  • Guest, we are pleased to announce that Hydrophase Ridesteady is offering an extra $50 off for JETBOATERS.NET members on any Ridesteady for Yamaha Speed Control system purchased through Sunday, March 9, 2020. Ridesteady is a speed control system (“cruise control”) that uses GPS satellites or engine RPM to keep your boat at the set speed you choose. On twin engine boats, it will also automatically synchronize your engines.
Cold Air Intake Mounting
LX210
AR195
I picked up the K&N Filter with the adapter to remove the stock intake box. Where did you guys mount / secure the K&N filter too?
Blue Hawaiian
Toronto, Ontario, Canada
jEt_jAk
SoCal
Which K&N filter did you get? I am interested in this also.
jEt_jAk
SoCal
Ah what the hell. Just ordered these. Will try this weekend :)
Betik
Frisco, TX
Not sure. My boat is runing stock filters.
DavisAR195
Happy Valley, Or
MasterCraft
The filter is not attached to anything no issues.
jEt_jAk
SoCal
Which filter is that?
DavisAR195
Happy Valley, Or
MasterCraft
It’s a K&N, I just looked at my thread AR195 Mods where I attached the original link and the product link was no longer valid.
jEt_jAk
SoCal
Done :) Going to find some way to secure it better though.
jEt_jAk
SoCal
Here is how I secured it
jEt_jAk
SoCal
This is it
Bowling Green Virginia
Are you guys noticing any performance improvement with the K&N filter? Have you also removed your "back fire preventer"? Anyone tried putting the filter directly on the throttlebody, putting a small filter check valve on the crank vent and getting rid of the intake tube completely?
jET_jAK, Why not remove the ribbon? I just did it today on my 2019 AR190 and it was a super simple process. All you really need is a flat head screw driver and a 12mm ratchet.
DavisAR195
Happy Valley, Or
MasterCraft
I have done the Ribbon delete "Spark Arrestor", Cold Air Intake and the engine breather filter. You definitely notice that the boat has more throttle response and you can hear the boost blow off more. Since these boats are supercharged you can't attach a filter directly to the throttle body as the air flows though the supercharger through the intercooler and then through the throttle body into the engine.
I have the none supercharged AR190. I doubt it will make much of a difference, but I may see about putting the filter directly on the throttlebody. And either directly venting the crankcase to the engine bay or running it through a vented catch can. I doubt the crank case see's much pressure to worry about alot of oil vapor.
jEt_jAk
SoCal
I wanted to do the ribbon delete but on the supercharged engines it is a huge hassle and seems to be little benefit from what I have heard. The non supercharged engines seem to gain more and are also easier to do.
drewkaree
Fremont & West Allis, WI
I know with my F150, the cold air intake didn't bring as big an improvement when it was buried in the engine compartment - running the hose to the sidewall made a more noticeable difference, and also negated the need for the K&N filter. I dunno if there's any way to run this same type of setup on these boats, but I'm thinking an adventurous sort could do a similar mod on the panel behind the rear swim deck seats. Here's the best layout I've ever seen of the mod, but if you wanna see a few other folks that have documented it, do a web search for Gott's mod.
Drewkaree, that brings up another question. Where do our boats draw their air from? What is the path it has to travel to make it to the engine compartment and what we can do to improve it.
