2kwik4u
- Buffalo, NY
How does the back end look once you've got that 24' hitched ? Does she squat a lot ? Or does the tow package add stiffer springs ? Currently I'm using my son's Dodge 1500 4x4 and a friend says that even that truck isn't big enough. I gave him all the specs on the diesel Colorado with tow package and he says No Way.
Really good chance that the 1500 isn't properly equipped for a 24ft. A good portion of the 1500 class trucks are sold with the wrong options (usually gearing and cooling) to tow a 24ft boat. I haven't dug into the Dodge specs, but I know that GM has a number of 1500 class trucks that are only rated to pull 5,200lbs or so.
Properly equipped, either the Dodge 1500, or the Colorado Diesel should handle a 24ft acceptably.
Anyone that says a half ton 4x4 pickup is not enough to tow one of these boats has no clue. Unless you have the weakest springs in the world, there is no reason it should not be able to handle it safely and within the load capacity of the vehicle.
The photo in my signature is of us towing our 242 roughly 1700 miles with ease.
Check the specs, you would be surprised how little some 1500's are rated for.
