Connext losing preset radio stations
Pro Build
South Brunswick, NJ
Is it normal for my connext to lose "ALL" preset radio stations every time I turn battery switches off?
Pro Build
South Brunswick, NJ
Instead of the preset channel it has the number and "Err"'. Between this and hours out of sync, I guess it is a sign.
AboveTheBest
Bloomington, IN
Maybe your boat wants you to join the Marine Corps...
Weeb
Denver NC 28037
My clock doesn’t stay set but the presets do.
Pro Build
South Brunswick, NJ
Out on the water today, stopped to look for whales, turned the radio on and what do you know, my preset channels are all there with no errors. Never know what's going to happen with the Connext.
Pro Build
South Brunswick, NJ
Old post, I know, any chance anyone has had the issue(please see picture) with all preset radio stations and preset rider/drive settings disappearing after turning off battery switches for only 30 seconds. Last year the radio stations came back at some point of outing(don't know exactly when as I didn't have the media screen displayed). Is there a memory wire possibly not connected. Thank in advance. If anyone has a picture of their battery connections for the exact same boat as mine, please post.
grywlfbg
NE Oklahoma
I haven't used the radio presets (FM reception is terrible so I just stream from my phone) but I do lose the drive control settings every time. Someone posted here somewhere (Super helpful, I know) that it is a known wiring issue that can be fixed by your dealer. I was going to tell them about it when I go in for my 10 hour service.
Edit: there's discussion in this thread:
Pro Build
South Brunswick, NJ
Thank you for replying, and if anyone has or gets this resolved, please post the fix regardless if it's by the dealer or not.
Scrodee
Please do share the details of the fix! Would prefer to fix it myself as the dealer is 100+ miles away...
Pro Build
South Brunswick, NJ
Today I found a way to retrieve preset radio stations. If I go to media And touch source and then turn off radio and then turn radio back on all my preset stations come back. However I can't find anything to make the clock or the rider settings stay once batteries which is have been turned off
Pro Build
South Brunswick, NJ
Playing around with the connext, I just discovered something that works for me. First thing is turn both battery switches on and after the connext is up and running turn your Ignition key on. Now you can set your clock and your rider controls and save everything and it will stay if you do the most important thing, and that is do not turn off your battery switches until you've turned the key off and the connect has shut down, after that you can turn your batteries switches off. And the next time you turn the battery switches on and they connects comes on, all your setting should still be there. The most important thing is to make sure your key is on when you're making adjustments and changing settings and make sure you do not turn your battery switches off until you've turned your ignition and the connexts has shut down, very important. Give this a try and please let me know if it works for you or anybody else. Never shut your boat down by turning off your battery switches. Always toggle the Ignition switch on and off to shut everything down before you turn off your battery switches. Again battery switches should never be used to turn connext off.
Pro Build
South Brunswick, NJ
If you just want to listen to the radio, turn your Ignition switch off and the connext screen will shut down and then you can turn your start battery switch off and go to the Stern of the boat and turned the radio back on from there. This will save your start battery from being used and discharged and it will only run off of your house battery.
grywlfbg
NE Oklahoma
Thanks for chasing this down. I think I turn the key off before I flip the battery switches but I can't say for sure. My boat is snugly under its cover right now so I'm not a good position to test it out but will flag this thread for when I wake her from her slumber :)
