Connext screen issue
john94si
Orlando, FL
SeaDoo
I had my screen replaced but the hours now read 99,999
Anyone know how to reset so it reads off the ecu?
Or get to the hidden menu?
john94si
Orlando, FL
SeaDoo
Ok it's missing the boatmodel number. It's 2105 limited s in the hidden menu under cntrl for three seconds.
subysti
east Longmeadow Mass
I can check my shop manual and see if it's in there.
subysti
Ok here are some pics. Might help. 20160428_103421.jpg20160428_103428.jpg20160428_103508.jpg
#Connext
<edited by admin to add hashtag>
john94si
Orlando, FL
SeaDoo
Yes that's it but it requires the 4 digit code. I'll have him hook old back up
john94si
Orlando, FL
SeaDoo
Ok the old screen does not retain the code. It's zeros as well as new
john94si
Orlando, FL
SeaDoo
3578 worked then scroll thru apply to see your boat current model ltd s
But hours won't update. Still 99,999. Ugh.
john94si
Orlando, FL
SeaDoo
Has anyone else had connext replaced if so please let me know if we can ask your tech how they did it
OperationROL
Knoxville, TN
Mine got replaced at 5 hours. Those 5 hours will be lost forever. I am not sure you can reset it. If you can, my dealer certainly did not know how.
john94si
Orlando, FL
SeaDoo
If it was zero i wouldn't care as much as it reads 99,999 ... they have the new screen i have to drive two hours to try again..
john94si
Orlando, FL
SeaDoo
Who has had theirs replaced successfully? My dealer tried again with another new unit and cant get the hours to read. If you had yours replaced please give me your dealers name so i can have mine call them.
Binymac
Los Angeles, CA
Mine was replaced by http://www.bertsmegamall.com/ (626)-974-6600 .......... Touchscreen was not working. Took like 2 months to get a new one but, they did it and everything works as it should now.
john94si
Orlando, FL
SeaDoo
very cool i will relay to my dealer.
john94si
Orlando, FL
SeaDoo
SO my dealer now states they cannot reset the milage when they replace it...
WTF... so the boat shows 99,999 and they are going to run it to watch it tick over to zero hours.. then return it with zero hours..
The hours should be in the ECU not the screen.
Binymac
Los Angeles, CA
Try calling Yamaha customer relations to see if they have a better answer.......My Connext system was at 20 hours when I had it replaced, never had to deal with the 99,999 issue.... Maybe the dealer is doesn't have the new Yamaha Diagnostic System version 2.0 ? ( Just guessing, I know that system is not cheap. Most shops only have YDS 1.3 )
john94si
Orlando, FL
SeaDoo
Did they return it with 20 hours then?
OperationROL
Knoxville, TN
Your dealer is misinformed. My screen was changed at 10 hours. The new screen restarted from 0.
john94si
Orlando, FL
SeaDoo
Rol can you share your dealers info please
This is the second time they have tried to fix my connext
OperationROL
Knoxville, TN
Mine was replaced by Hammertime Sports but they are no longer a dealer. Http://hammertimesports.com
Actually, my current dealer swapped mine out with another boat and then back again when they were chasing my sprayer issue. Http://Nielsens.com
