rkim808
- Kauai, Hawaii
Aloha Gang, need some help so I’m planning to cross channel and shoot across to the Island of Ni’hau soon. I’ve been noticing on my last couple trips out, that the bilge been kicking on every 10-15mins or so. And when I’m underway I can hear water sloshing around in the hull. So came to the deduction she’s taking on water somewhere. I read a few leak threads and decided to check thing out and filled up the bilge/transom compartment with some water to check if drain plug or any water was leaking out. Nothing no water leaking out anywhere, so decided to add more water to the top of the clean out plugs and clean out tray/cover hatch area. Of coarse water leaked from the inspection cover into the bilge/transom area. Then crawled under boat and found a few things:
1- Is this corrosion Or electrolysis, and how can I take care of the issue?
2- Found out starboard side clean out plug leaks.
Would this leaking clean out plug cause me to take on water into the bilge/transom area? Do u recommend replacing or rebuilding the plug? Any and all advice and tips would be greatly appreciated. Don’t want to make this longer trip without figuring out this problem first. Mahalo nui loa(Thank u very much).??
