Cushion 4 2011 Yamaha ar210
Newbee76
Hello,
Anyone having luck on replacement for the cushion or where to get one?
We just bought our boat and didn’t know it was a common issue to find cushion number 4.
I just spoke to Auto Interiors in North Carolina. If there is anyone that can lend them the pattern for foam/wood they would be able to knock out a bunch of replacements.
any info or advice would be appreciated
Thank you
I know @Mgbrown82 was recently dealing with a cushion 4 loss. If one was made, it would be fresh in that upholstery shop’s mind.
I'll ask dumb question #76: which one is cushion 4?
Item 10 in the IPC diagram (p/n F1T-U375F-11-00). It’s the small one behind the passenger side windshield that likes to eject if you don’t use the cover trailering.
Alas, my boat does not have that one. I was hoping it would be like item 23 (I went and looked it up), the rear one--that is the one the AR240's always lose. But I still have mine (I think it is behind the batteries back there--never use it!).
Thank you for checking. Yes, the shop I called in North Carolina said she has like 15 requests if someone can give them the pattern for foam ans wood. They have the material.
I was able to make the base myself out of 1-2” pvc it is at the upholstery shop now being built. I will update everyone on how it turned out when I get it back
Awesome thank you for your response.
I appreciate your time.
Any update? Been searching everywhere to replace this seat!
Still waiting on the finished product
Check out this thread, another user had a similar issue and is getting his remade seat copied for others to order from this shop.
Replacement Cushion 4
Any updates on getting Cushion [HASH=550]#4?[/HASH] My 2nd replacement just flew out!
Auto interiors and tops in Raleigh NC. I had them make me a #4 cushion last year.
Awesome, just called them and they are sending me a quote. Thank you for the info.
Information to them is posted in the link above. Here as well Follow this
They also have an account on here. Check out the last page on that thread, they are listed there along with pictures on the one I had done.
How did they get the dimensions for the cushion?
They had that on file from someone that had to get their's redone.
