geohil
- Salem, Oregon
- X
Yours is at the chrome handle.Nope - bad pic but the 212X makes tying a bag on the upper deck tough.
Thanks.Just an FYI, this past vacation I used the air pump to inflate my bag and tie it down. Then I used my pump to fill the bag while it was venting air. 100% worked as expected. I never had it easier to fill the bag.
Same for us loved that we put less time and effort filling bags !Used less ballast didn’t fill my center ski locker at all and only had 3 adults in the boat and 1 surfer which is a smaller crew then usual when we go surfing.
That looks freaking great.@swatski here is the picture when the bag is filled full it doesn't cover the vent. This is a little deceiving because in person there was a bigger gap probably the angle of my picture.
View attachment 77077 View attachment 77078
Working on it...Are you coming to shelbyville this year?
So, a little update on "surfing with the swatskis", lol
First of, the swim deck bag really is the bomb!
Kudos to @0627Devildog and @jcyamaharider for making this a reality, honestly I think between this bag and the wedge those are my last hard surf mods/purchases.
Now - just need to dial it all in.
That bag alone pushes the swim deck under water
Filling the bag with air first (before replacing the air with water) works very well.
Especially at first, it is very useful to get a good feel for the size/shape/position on the platform. Towards the end of the day, after a couple of test fill-ups, I was able to fill the bag with water strait up with almost the same result, albeit the bag was slightly more "spread out" as far as its footprint.
This is of some importance as the bag does interfere with the air intake, at least in the AR240s like mine. So - if filled up with the air first, the bag holds its shape better - no problem with intakes, as below.
However, if filled up with water - strait up - the intake is obstructed to the point the air flow may be restricted (you can feel the air being sucked hard - with your hand).
I used a bumper to keep the bag from smothering the intake, as shown below.
I'm using one of my 4 integrated Johnsons to fill up (the right one on strb side in the pic below) - the black quick connector (in the top pic) works perfect for that.
Of note, the bag fills slower than my other 800lbs bags (with "black on black" quick WM connectors) as the grey "quick" connect ports are 1/2" reducing the ID and providing some obstruction (which I do not have w/other bags).
(the hose I use here is the 1" from WakeMakers - I think its the best hose there is)
W/ swim deck ballast alone (and the wedge) the wake looked okay already:
After filling the center locker 800lbs it looked downright good:
(w/no other ballast in the rear/side compartments filled)
The wave was very surfable (again - w/swim deck plus center locker bags only, NO other ballast).
My 12 and 14yos had a little fun with it before we needed to boogie for the night:
My 16yo could easily keep some slack on the rope, albeit none of my kids are surfers, yet:
The side/rear bags (when filled up) will certainly improve the wake!
I feel I still need to find the right angle for the Wedge (@jcyamaharider - I could use some help with that!)
Overall - I feel we are getting pretty close to what I would consider a sweet spot for surfing w/this boat, with minimum setup effort required (a critical issue for me).
Boat runs easy, in high 5k RPM, but we were not fully loaded.
W/ swim deck bag only:
Or similar w/swim deck plus center locker:
