- Florida
- Other
- Other
I have a few of the Ultimate type fangs in stock that I am liquidating, If you added only 2 fangs to your twin engine system and you would like to enhance the reverse control the reverse stopping power and the power steering effect above what you already receive from your 2 fang setup this would be a good opportunity to pick up a pair of fangs with the hardware for 50 dollars shipped in the U S A, or if you wanted to add fangs and you have the fang compatible base plate you could add 4 to a twin engine setup for 100 dollars. I am serious when I say I only have a few available.
I have a new design I am getting close to releasing but the price is a bit more than the originals and the compatibility target is for all Yamaha jet boat nozzles With the exception of the 19 foot keel boats " sorry the little keel in front of the rudder is in the way" HOWEVER the VIPER will get that job done quite nicely as we already know.
I am also targeting Magnum A K steering systems and most of the plastic part time systems .
I am also making these as a stand alone system, so if you just want some unbelievable reverse control with power steering and improved braking this new MEGA FANG SYSTEM is something you will want to add to your boat when I release it.
And yes I do have some in stock however I am taking advantage of the off season to make any final adjustments to accommodate the various steering systems. So people who may be interested in this project who would like to work on the adaptation for other systems feel free to contact me.
IF you want to know how it works on the MAGNUM A K system in place of the single A K fang setup there is a member who has had experience using it on his 24 foot boat. This system uses two MEGA FANGS per nozzle and an independent base plate for mounting on your nozzle. This new system will sell for 85 dollars per nozzle if you already have the base plates like the regular Magnum steering or the ULTIMATE steering, with an additional 25 dollars per base plate and necessary hardware if you do not already have them on your nozzles.
I want to remind you the power steering effect actually reduces the work load on all your steering system from the nozzles to the helm , the part of the fangs that extend forward past the pivot point of the nozzle actually helps to turn the nozzles by canceling out resistance caused by the inside jet stream trying to straighten the nozzle and any added resistance from steering fins . The reverse control improvement is created by the fangs directing the water exiting the bottom opening of the nozzle when you close the reverse gate by corralling that thrust under the boat in a tighter pattern also improving the stopping power by directing that water under the boat in a more defined stream. So the big difference here is that size really does matter "in this application " And having two per nozzle also makes a big difference.
I do my best to keep these mods cost effective so the difference in price from the original sets per single nozzle is only 10 dollars and the base plates with all the necessary stainless hardware is very low also. For the 19 foot boats pre keel this system with the Ultimate steering is also a very good choice along with the VIPER.
On the 19 foot keel boats the VIPER provides the power steering the enhanced reverse and stopping power with the added planning assistance, it was the longer fangs built into the VIPER and the customer comments as to how their boats steer as well in reverse as they do in forward that actually convinced me to go back and revisit the fangs that I started offering back in early 2016.
