Scottie
- Helena, Alabama
- X
Absolutely. Here's the fans I picked up from summit racing. These are the same ones @gmtech16450yz used, best I can tell. https://www.summitracing.com/parts/spu-ix-30103013This looks so good. Would you be so kind to post a link to the blowers, albeit I realize those may not be doable in 240s as the aft bulkhead is totally different, but they might fit.
I'm assuming you are having them both blow out, correct?
I cut the holes with a 6" hole saw. That was the trickiest part. I really needed a 5.75" hole saw, and I'm not sure you'll find one of those. It worked out fine, but my bolt holes were actually touching the 6" hole, and there's just a little space around the outside fan ring. A slightly smaller hole saw or a slightly larger fan would have been just a bit better. I cut the factory blower connector off one of the blowers and wired both fans to it, so it connects just like it did originally, controlled by the blower switch.
