swatski
- North Caldwell, NJ
I understand the idea, but that is just not the case. The water from outside is not reaching the cylinders in any of those ballast scenarios. It can happen when it is pushed through the exhaust at speed or if the intakes start taking it.If water can make it into the cylinder while towing it is possible. You may not get hydro lock but if the water is making its way so far up the exhaust and its hitting areas that are obviously hot it could be creating steam vapors that are throwing off the combustion mixture. The only way to rule this out is to pull a plug and look for moisture. Or the manifold cooling lines in relation to the water level could be the entry point
A "good foot plus" is inaccurate confirmed measurements from an AR230 the center of the impeller shaft is 14'' below the lower swim deck.The highest point of the cooling lines is 10'' above the center of the shaft so that if the water is level with the swim deck its only 4'' above the highest point in the cooling lines . Different models but they are most likely close take some measurements with it sitting on the trailer you will be surprised
If the rear swim platform is 4'' under water its almost in line with the highest cooling line the variables are the boat is most likely sitting lower in the back and not level but with the large wave following the boat will make the front end drop and a rocking motion could allow water to works it way up
If the boat was completely balanced and pushed straight down at some point the water level will find its way into the cylinder I think this point is with the swim deck 4'' below the water line. Water will equalize and with these boats loaded with ballast I think your very close to that fine line
Someone needs to pull the plug it would be great to eliminate this possibility and may even be hard to determine but take a look
When ballasted, the boat sits w/ nose up, so these measurements are completely off as far as the water plane, it is a foot plus in my boat as far as exhaust manifold parts etc.
In my OEM exhaust the water will not get past the water box, if any would flow (above) and through the resonator at all, unless the boat was sinking...
The water box is always cold or cool, it never gets hot. It is sitting in the bilge not the engine compartment, which is smart. Everything gets hot in the engine compartment.
Of course some water vapor/fog will be created in the exhaust but that will not lock the engine and will be expelled with the first crank.
