Cambo
- Long Island
- 242X E-Series
The water may not be enough to be noticed in the oil . Next time someone has hesitation pull a spark plug and take a look, try to take one from the back that will be the low point and preferably after only a short attempt to restart so it's not gas soaked. These motors sit low in the boat and water may be close to the cylinder level of the cooling lines as the boat rocks a small amount could seep in. Put a level at the cooling lines were they exit the cylinder and try to get an idea of were that transfers to the outside of the boat when loaded with ballast if you are within 6" as the boat bobs around it could easily weep in.I have not had any evidence of water infiltration into the oil. . . . and I surf religiously.
