swatski
- North Caldwell, NJ
the water pick up line is in the jet nozzle at idle this is below the water line but load up ballast and it gets pushed very deep under water especially when the boat comes to a stop when the wave washes up on the back deck add in the extra pressure of water. This water gets forced into the exhaust on the opposite side of the water lock
I think @Cambo 's theory is a good theory. Well-reasoned and well-thought out.
I don't even know Why I'm responding, this starts feeling like beating a dead horse, sorry!
The intakes do not lead to cylinders (directly), the only way for water to get there is to completely fill the exhaust first... That will simply not happen with the engines ON.
So- assuming the engines are ON while surfing (sic) the wave washing up and swamping the back deck, could be a tsunami - I don't care, it is not moving up the exhaust, or accumulating in the exhaust, with the engines ON...
You really have to work on it to get the water past the waterlocks/boxes in those engines - it takes moving at speed with the buckets down, wherein water is pushed up the intakes (under the boat) with the buckets down water can enter (through the pump intakes) all the way into the exhaust and fill those up - due to pressure building in the pumps (when for example towing at speed with the buckets closed/down).
The above scenario can only happen WHEN THE ENGINE(S) IS OFF and the boat is moving fast, with the buckets down.
Alternatively, it can also happen on the hose with high water pressure - when water pressurizes the system as the flushing ports are above the seats in the gunnels.
Again, ONLY when the engines are off and the boat is moving or being flushed on a hose (water entering at high pressure through ports located above the deck/seats).
Sitting in the water with engines off will NOT lead to hydrolock under any but the most extreme submerging conditions, or engine bay swamping (albeit that would let water in through air intakes not exhaust, so that's different).
