Welcome to Jetboaters.net!
Coheeba...3 seconds did the trick. I guess I was use to the immediate response when pressing a float mode button on the water (both battery switches on)
Leave the start battery off but turn on the parallel switch and clear your alarm. Caution, your engines will start with the switches in this position but you wont get the low batt alarm.
thank you for the input but i think thats a terrible advice. that kills the start battery.
i figured it out already thought.
key off
start battery off
connext will go off and you can play music from the rear deck.
house battery only no alarm all is good
Then what's the point of having the parallel on if it's not drawing from the start battery? My connext works with just the house battery on, all other switches off.
You only use parallel in emergencies to start your engines. Basically combing all battery banks to give you an extra boost. Besides that you don't need it. Parallel should never be used if your banks are set up correctly. Your start battery should never drain if you don't connect your electronics to it as when you are running around it's being charged by the stators. Hence hook everything on the house batteries except for the engines.
Your right....i forgot i swapped the wires on my switches to prevent just this problem....
So now my engines goto the "A" terminal and the battery and DSVR goto the "B" terminal....in addition my Connext voltage sense wire is now connected to the "A" terminal.
