Mainah
- Chapin, SC
- Limited S
So I checked the wiring diagram and unfortunately it does not spell out the connection to the batteries after the power distribution block. However I can confirm that the solar panels are wired direct to the power distribution block along with the main power supply to the radio head unit. Coming off of the power distribution block is a wire labeled SLR PNL+ or SP+ (the document is conflicting itself on this) wither way it is terminated on a ring terminal near the battery switches so this must be the wire that @Julian is referring to and confirms my warning above. Not assuming anything if the SP+ wire is connected to the house side of the DVSR as opposed to the start side then the start battery never gets the benefit of the solar panels and if it is connected to the start side then everything I said above is correct.
So boiled down version of what e-series owners should do.
1.Make sure that the SLR PNL+ or SP+ (could be named either) is connected to the start side of the DVSR.
2.If you don't use a multi bank plug in smart charger then end here and do nothing, else go to step 3
3.You do use a multi bank plus in charge and you do want it to be smart, go to step 4
4.You should should add a relay with the correct wiring that I will post after an e-series owner confirms what I have above and tests the wiring that I send to them to confirm (I need an e-series owner volunteer who understands relays and does good wiring). Alternatively just see step 2 and be ok with your multi bank smart charger being dumb, worse things can and will happen.
