swatski
- North Caldwell, NJ
May very well be true. I was basing my thoughts on what I was told by the salesman, and the fact that they advertise the solar panels give you up to 30% more time while anchored without engines running.@captras I was told by someone from Yamaha that the solar panels are connected to the DVSR, which defaults to charging the Starter batt first, and the house battery 2nd. I do not recall who from Yamaha told me this and if they were corporate or dealer folks...but this makes sense to me.
You can run all your systems off the house battery, leaving the start battery for your engines. I have done that since the beginning and had no issues. Withe JUST the house battery switch on NOTHING works until you depress the SYS CTRL button. There may be other ways to energize the system, but this is what works for me. As far as the solar panels, it is my understandING that they ONLY charge the house battery. The EMERGENCY switch (yellow), to my understanding, can be used if your stay battery is low. This connects the 2 batteries together and should only be used for that purpose. If you leave the EMERGENCY switch on you drain both batteries. I hope this clarifies things, and solves your issues.
The voltage display on the connext displays house or start voltage
There are two separate potential issues:The voltage display on the connext displays house or start voltage
Pretty sure current from both stators goes to the DVSR which routes to starter first then house.or does one motor charge house and one charge start.
Ok so now I'm a lol confused. I'm following with the cutting and capping and running new wire to each battery for the connext voltage display fix but I'm confused by cutting loop on dvsr. Why would I want to do that. Thanks, this battery issue was really bugging me
