BoaterDave
- Illinois
- Limited S
I would install a relay instead of a switch. Have it disconnect whenever voltage is sensed from the charger. I am unfamiliar with the circuit but you may need to add a diode to prevent the battery back feeding the relay and it always being tripped.
Even easier, pull the black wire from the DVSR off the negative on the house battery and put the nut back on then go to the hardware store and get a wing nut that is the same size and secure just that 1 wire above the nut on top of the negative stud. Disconnect anytime and no cutting.
