I saw this conversation on one of the Facebook groups, I do believe you brought it up there as well.
I swear, all of the comments of "you should never run your boat in that depth" are the same guys that were singing the praises of how shallow they could drive their boat in compared to an outboard or I/O boat when someone asked why they went with a jet.  What's the point of bragging about how shallow you can drive your boat, but don't have the guts to do it.
Here's my take after watching Will's video on how much is taken in at roughly 2' of water.  If your bottom is primarily sand/silt, go for it.  At idle you may be sucking a steady stream of light sand through your pump.  Will you damage it, minimally, will it over time possibly.  Would I worry about it, heck no!  If it were small rocks, gravel, or a clam bed, you bet I would.  As those things can ding up the impeller, jam in the intake etc.  The sand will wear the edges of the impeller and surface of the pump sleeve, and over time cause cavitation.  Over a very long time.
So long story longer, we gambled on our forever lake home January of 2020.  We bought it with ice on the lake, as it was built on a private bay, with a channel going out to the main lake.  We had no idea what to expect, but knew pontoons were going through it on a regular basis. We know what we draft and what I am comfortable with at idle speed and on plane.
Come to find, the channel is maybe 75yrds long, 15' wide and 2ft deep (at it's shallowest point).  Soft bottom with some known big rocks, but very easy to avoid.  So in other words, while I went through in the spring during low water weeks, I watched and tested.  We even walked the channel to find obstacles and test depth as we didn't trust the Simrad.
By week three, I was rocking that channel at 40 on plane.  It was very safe, and on plane the hull was safe.  And quite honestly, I think by running our twin 1.8's through there, it may have even blown the channel out a bit.  Our neighbors are not filing complains with the DNR, that's for sure.  They appreciate the clearing.  As at that speed, I'm not picking anything up.  It's when doing it at idle, that the jet creates that vortex of sand.
In your case, you may not have the option of going through on plane.  And technically, I'm illegal as well, by law, it's a no wake zone.  But a well known channel like we have, I have no issues.  But you won't find me running unknown water at those depths.  I'm the first guy to jump off the bow and walk our boat into the party cove for sure.  I like the shape of my hull and the lack of cavitation in my jet pumps.
Good luck,
