AboveTheBest
- Bloomington, IN
- Limited S
Ugghh
Sorry you are having issues!Went out yesterday and had about 5 minutes of pure boating bliss before problems started again.
When I first backed it off the trailer I heard a “clunk” as I applied power, but it wasn’t followed by any other noises or problems.
It seemed like it was a bit underpowered and when I took off across the lake it started losing power and bogging down the engine.
Fast forward through 30 minutes of me with a ski rope tied around my chest swimming the boat back to the ramp...
I got it home and took the pump out this morning and took the cone off to make sure the noise I heard wasn’t a bearing exploding or impeller snapping. I changed the oil and pump new plugs in (just because I had them), and ran the boat with the pump removed for 5-minutes. No power loss or any other indications, which means the problem is somewhere outside the boat (thank God).
The impeller housing(s) are both deeply grooves by the impeller, and I’m assuming this is the cause of my new problem (pic below).
I’m getting ready to order the two housings and maybe even a new impeller, but I’m afraid the problem may be with an improperly aligned intermediate bearing. If I replace the housings and something is skewed it could ruin the new parts as well.
Anybody have any suggestions?
