rad1026
- Albuquerque/Havasu
Dang Trev, I'm such an idiot. This whole post is crap. I have a DC Tv in my RV. I still think you are doing an awesome job though, that part isn't crap.I wouldn't over think it. Today's LED TV's pull minimal amps. Check the draw of the TV. I run two 6v golf cart batteries in my RV and run the TV all the time with no issues. I have a cheap amp hour meter hooked to my system that tells me my true voltage, not just the stupid lights that are on a normal RV voltage indicator. I know that my two golf cart batteries are, I think 100 amp hours? That is off the top of my head. If the tv is only drawing 1.5 amps, well that's a lot of viewing before you have to worry. Without a doubt the best thing I did to minimize amp hour draw on my RV was to replace all lighting with LEB bulbs. If you haven't done that do it! Makes a huge difference. You did the right thing with the two 6 volt true deep cell house batteries. One thing you have to remember is, it takes a LONG time to charge those batteries. If you let them get low, you will be running your generator for a LONG time to charge them. You also have to make sure your on board AC/DC converter is rated to charge multiple batteries. I'm sure since you are starting from scratch you researched that before you purchased your converter. I think you are doing an awesome job!
