First time jet boat owner and I think I have my first case of something jammed in the impeller. I have tried the recommend approach of opening up the clean out port but can't seem to find anything. I have read in other threads it's quite possible it is so small or wedged into the impeller it is difficult to extract without taking it out of the water. My question is this, is there anything I can try while still in the water to dislodge it... I read about the revers kill maneuver where you build up speed in reverse and then kill the engine and move the thrusters forward but somebody from Cobra steering suggesting that likely won't work with the newer model Yamahas. If I have to pull it out I will obviously, just want to try in the water first if there is any recommended ideas. thanks in advance
You've got a lot of things you're looking at, and you're not really following what each of those things are, and how to tackle them or why they're used. Not a bad thing, but you need to concentrate on the symptoms at hand, and the things you're mentioning ARE specific to certain symptoms.
"I think I have something jammed in the impeller" You said your take is that the recommended approach is opening up the clean out port - the impeller is WAY down in there, and you will have a difficult time, at best, finding anything via that route with the boat still in the water - and you imply that you haven't taken it out of the water.
I view the clean out ports as "seaweed removal ports" or "sucked up rope viewing holes", as everything else is likely to require you to pull the pump(s) to access or remove them.
You read the reverse maneuver, but not WHY the reverse maneuver is often done - to clear small blockages of weeds from the intake grates. If you've got something wrapped around the impeller shaft, or stuck in the impeller, the reverse maneuver isn't designed to remove something stuck in that fashion. Whatever you read from Jeff (Cobra Jet), I'm certain he was either referring to
specific newer models, or was simply pointing out that it may or may not work, depending on what the issue is.
If you have something stuck in the impeller, you MAY be able to reach it through the clean out port, but you have no idea what it might be, and you may end up injuring yourself if it's something sharp, like a shell or hook, or who knows what. You will be far FAR better served pulling the boat out of the water, and pulling your pump. You will want to check the condition of your impeller, and the best way to do that is to pull the thing. It's a simple process, you'll have to remove 8-10 bolts, and other than a socket set, you'll need a pry bar to break the sealant bond on the impeller portion, and the impeller will simply slide out, at which point you can check everything out.
I think you have the newer pump design - they definitely changed the design as of 2019, so I think you've got the same setup as me. I'll post pics for you shortly, as I just had to do this recently. You get the benefit of this forum, and others doing this before you - this is easy, you got this.
