chesbay007
- Annapolis, MD / Chesapeake Bay
So I started a thread yesterday about buying solas impellers and having them custom pitched for starboard and port engines. I ordered the impellers and custom pitch upgrade yesterday from Impros. I than read a post that states " Yes anytime you repitch impellers, it affect the diameter- either makes them larger in areas, or smaller. When it grows, we machine the O/D so that it fits into the pump, and when they get a little smaller, we can't do anything about it, however the benefits to the repitched impeller far outweigh the loss of clearance at parts of the blade. David @ Impros" I then read another posts that after you repitch "When they get a little smaller, you weld, then file". It appears that the repitch of the impeller helps but also makes the impeller smaller in areas which leads to cavitation. Would the correct way be to repitch and then weld the smaller areas back to spec?
Old Thread
https://jetboaters.net/threads/impe...ustom-pitch-warranty-voided.9545/#post-163162
Old Thread
