That's a pretty sweet placement. Wonder how he ran the cable up into the hull? Drill a hole through the ride plate? I had about given up on the idea that I could make any transom mounted transducer work and was going to drill a 2" hole in my hull like the stock one was, just on the other side.
I think I understand, you'd like to see how the wire is routed from the transducer and up to the hole in the hull then? Yes, I don't see that. It does look like there may be a gap in the ride plate to run it through. These other threads may be useful. Conversation seems more centered on how the transducer is attached than how the wire is routed though.
I've searched quite a bit, looked at those and they look familiar. So, there's a chance I've stumbled onto those the last few weeks while searching. Looked them over once more to see if I could gleam anything new.
