ken4motion
- 252SE
X 2If your winch stand is bolt in place you can loosen it, slide it out of the way, do your work, and then slide it back in place.
This is exactly why I bolted the winch post instead of welding it.If your winch stand is bolt in place you can loosen it, slide it out of the way, do your work, and then slide it back in place.
Awesome idea!!!!Ok, mission completion on the roller. First off, to get the bow off the roller I placed a wood board on a floor jack and raised the jack enough so the wood touched the front bottom of the hull. From there, I lowered the tongue just enough to have a workable space. I have to thank fellow member Leojay for that idea.
The bending of the mounting tabs was somewhat involved and it took me some trial and error to get it riView attachment 12203 View attachment 12204 View attachment 12205 ght. I used a vice grip and an open end wrench to get the right articulation of the tabs. On to the bow shield install!
The bunks carry the boat. The bow roller keeps the boat on the trailer when you have to jump on the brakes, it is a bow stop and that is all.So, the bunks will support the boat enough to not need the roller?
yesSo, the bunks will support the boat enough to not need the roller?
Where did you get the shield from?
