Is there any good vids or pics showing how to lengthen tubing ropes?
noboat
Fargo ND
I would like to see how to lengthen tubing ropes. I have read some post about it but I learn from seeing better. Thanks!
Jameson Clark
Laurens, SC
What do you mean? Most tube ropes are 60' and ski ropes are 75'. I use a ski rope with the handle removed to tow tubes to keep them out of the jet spray.
I use two 60' ropes for longer tows, the arrow points to the knot. Use your favorite knot (e.g. double fisherman). Works very well for towing strait, like when you want to just go somewhere and they want to ride the tube. I wouldn't go fast and watch them like a hawk, things can happen fast.
Here is us running away from a storm - these are two ropes tied together.
BTW - we made it back, lol
noboat
Fargo ND
I guess I meant how to splice in like 10ft so my 60ft rope was 70. I didn’t think about using a ski rope.
MidnightRider
Zumbro Falls, MN
Malibu
Wake
I've used this method to put loops on the end of nylon ropes for years. They never let go and last forever. Once you have the loop you can link it to the end of another looped rope as you normally would (like on a multi-segment ski rope).
RiverRatSx210
We used a ski rope for the longest time, great whip, kept the tube away from the spray. Until I mistakenly sucked the rope and had to cut it...
We bought BOB which is the inflatable ball that goes between ropes.. it sucked. So we used one of the ropes originally attached to BOB and the rope that came with our tube, works great!
zipper
Boston Whaler
I use most of these knots whenever we go out or in, especially on the sailboat. The sheet bend maybe what you need. I use the bowline alot, it does not loosen or slip
Jgorm
San Diego / Colorado river
Be gentle with whips on a long rope! People will cartwheel across the water. Someone told me today they could hold on no matter what. I laughed and asked his experience at flying a tube. He's a strong man competitor, but there is still no way.
This is such an important point!
I generally hate pulling tubes for that very reason. The kids love it and it is fun... until it is not, and it can happen in a hurry.
I've learned to be super conservative, ignore "go faster" signals, still at times it can get dangerous so quickly. Ugh.
ripler
Just south of Pittsburgh
MasterCraft
Just a heads up if you boat in an area that's patrolled, there may be a maximum rope length you are allowed. In PA the maximum water ski rope length is 80', it doesn't specifically mention anything about a rope for tubing, but it probably safe to assume it's 80' also.
RiverRatSx210
I think mine is around 70’
We went from a ski rope to the rope supplied with our tube and kids hated it.. I’ve whipped an adult pretty hard, and couldn’t get him off our new HO sidewinder even on the extended rope. Btw if your looking for a new tube the sidewinder 3 person is awesome for towing, it has a assisted lift bottom and my boat hardly loses power when making small turns with the kids, it’s great not having to play with the throttle constantly.
sethman919
Apex, NC
Ill have to check this one out too. We have a big mable and when you whip kids around they smash into each other. i like the dividers on this. We tow using a powerball. never really tried without it. I know there is some face spray. kids usually just wear goggles. Not sure if the spray is from the ball or from the boat.
RiverRatSx210
So we tried the power ball with the ropes provided, and it didn’t help with the spray plus the rope was too short. So we took the tow side rope off the ball and replaced it with the supplied tube rope, still they kept getting sprayed. I’ve even shortened the boat side rope placing the ball closer to boat trying to cover the jet spray every thing made it worse.. so we just flat out remover it and kept one of the ropes from the ball attatched. And they were much happier. I have a 8,10 and 12 year old and they haven’t complained about the spray yet.
If you do a slow sharp turn the rope will dig in the water when towing from the transom hook and some spray will pop off the rope but that seems to be about it.
sethman919
Apex, NC
That was going to be my next question... where do you tow from. Do you mean the ski hook on the transom? I have one of those Y things are tow from the lifting hooks. I've heard of tubes digging in a higher speeds and causing all sorts of damage to things like towers and tow hooks.
Jgorm
That's not a great location. I'd rather tie in a 500 to 1000lb test "fuse" and tow from the tow point. I've done lots of stupid shit with a tube, but never caused any damage. It's the 10+ foot of slack while getting up to speed that breaks things.
zipper
Boston Whaler
The intended use for towers is for wake boarding. Tubes, especially multiple person tubes, should be connected to the ski transom hook. Too much weight for the tower with big tubes and multiple adults. Should be a weight rating listed on the tower.
